Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
- Oct 15, 2019
- 650
You are blessed to have her help.
Yessir. All the PB I've made to-date on this project has had "hair" in it.Did you add chop strand to the pb? Knowing your skills I'm sure you did.
I'm just copying what @PC on the Bayou did, and a video I found on YouTube - don't give me the credit for the creativity.Interesting . . . We have not seen such creativity all that often . . . usually folks just double up the wood at the joint area. It will be interesting to see how that works out![]()
Thanks, Buck. Yeah, we are on a similar mission but attacking it from different angles. I appreciate your thread on your restoration, and all the other active members on this forum as well.Looking great Tod! I think it is funny I am finishing the deck before doing the transom and you are doing the opposite at almost the exact same time. My deck doesn't touch the transom so that is why I am doing it this way.
Keep the pics and updates coming!
Buck.
Thanks! Yes, your thread was inspiration and the jig worked great.Looking great. Using the jig and router sure makes doing the scarfs easy. I like how you used the screws to align everything so they don't move. I found that parchment paper worked really well, as well, to get the resin to release.
Nice Work!!
Good idea on the strip length. Probably not a big deal for the stringers since they won't be seen, but I'll definitely make a mental note for when it is time to do the floors.Awesome work Tod! Even though my project is probably half of your project I used shorter strips also. When I tabbed the top of the deck to the hull I used different length strips for the 2 layers so the seams wouldn't end up on top of each other.
No, my measurements were at the top where the cap goes. Maybe I'll pull it in another 1/2". It would definitely spring back if I released tension now. I was even thinking about dropping the cap on with the ratchet straps in place then cutting them off, if I had to.I used ratchet straps to pull my hull to dimension across the beam, also. I was meticulous to keep it at the recorded widths, but in the end, it still came out a bit wide when I released the tension.
So if yours has any amount of tension holding the sides, the sides may be curving like a bow until they start to pull it together at the chine, which is where the floor will join.
Maybe you took measurements down near the chine, but if not, you may be wise to pull your beam a little extra to allow for the spring-back. Thinking maybe a half inch? That's about what mine needed.
The cap still went on, but it was a bit of a struggle.
Food for thought, in case you didn't have enough already.
