My 06 90 hp johnson suddenly stopped no spark on any cyl. pulled black/yw wire off CDI still no spark.?? tried checking ohms on stator, brown / brown should be 900-1200 i get 1.103 ( which i believe would be 1100??) dva should be 150-400v I get 219. org/org wire ohms should be 50-60 i get 57. dva should be 11-22v having trouble getting the right reading. I set meter to 600v i get 4.5 set meter to 200v get 43.5 set meter to 20v i get a 1 as though its to much to read. ??? not sure if there is a way to test optical sensor. thinking of replacing CDI box (power pack ) just dont want to throw bad money at it or toast new one if another problem. Any input is appreciated.!!
