I’m back…..when replacing the plug wires I found the green wires from the coils were connected to the wrong points. Switched that as well as put new plug wires and caps and it runs now!Carburetor / fuel issues usually turn out to be something else.---Not a compression issue.-----Pull the flywheel.----If the 2 coils are original it needs a new set.----If coils have been replaced ( most have been ) you might clean and set the breaker pointes.
Just getting small spits of water from the holes on the drive shaft housing and the engine is getting hot so I am assuming the water pump is bad.
