- Mar 8, 2009
- 43,436
OK … assumed different threads as in this video the guy goes to pains to explain having gearbox in forward for 1 prop and reverse for the other.
My mistake
i ass/u/me they are lock nuts with a nylon insert.Simple Q ...... assuming front prop (inner) is left hand threaded nut, and rear prop (outer) is right hand threaded nut.
As there is no locking tab washer or split pin .... what keeps the nut from working loose ? Particularly the rear (outer prop) nut.
Perfect. Thats a lot for that tool …Tube cost nothing, neighbour run it off for me.
so a little workbench ti e today and will have it complete.
The UK price for tool was $198.
They are both right hand threads. The video is correct though about you have to have it in forward for one prop and reverse for the other.OK … assumed different threads as in this video the guy goes to pains to explain having gearbox in forward for 1 prop and reverse for the other.
Or a 2x4..correct. That is what I usedOf a 2x4 right?
Out of curiosity, is that an OEM manual?My Manual (4.3 280-C-N) states
45Nm for the rear prop at 100Nm for the front prop.
Are your drives the newer ones with the helical prop splines?Yes ….. It’s the official VP manuals that they provided links to based on my engine & drive serial number …provided when engine/drive were register.
