1974 reinell cuddy restore
I'm thinking of useing this corrogated plastic sheet. No rot. Then attach headliner.
most boats today, the headliner is 1/8 or 1/4 PVC proboard with vinyl glued on it. then the panels are held up with either fast clips or screws and finish washers.
froggy1150
Master Chief Petty Officer
So the boat rehab has been put on hold due to me getting rehabed with some new parts. I had done wheel bearing and complete braking system before getting cut. 1 knee done 1 to go
kcassells
Ouch! Well you'll have plenty of reading time and helping other guys here Frogster!
Best of luck with it all and rehab. Can't you just glass over those stitches?
froggy1150
Been 3 weeks. Metal/plastic knee joint is set. Access hole is mended. Just need to build up walking muscles but I am already walking ok. Just not for any real length of time before it gets sore
froggy1150
Sooo.....
Getting close. Went thru trailer and replaced surge hitch, brakes, bearing, seals, tires, wiring, and drove it to dmv for a vin check so it can be registered. The only thing I got left for the trailer is guide posts if i want and also was thinking of putting a small ladder in the front so i can crawl down from bow. As far as the boat i am down to a lot of littles. At this point I could throw the prop on and go cruise if both had current registrations.
froggy1150
Hell been back to work for bout a month. Getting 6 miles a day on that peg. Just have to do it in short bursts due to muscle fatigue. Besides I dont wanna take your title of slowest build of the century from you..... I just wanna be close second @kcassells
kcassells
Your doing just fine! Very glad to hear that.
Looks like you're catching up to me. now. Just a couple more feet you are there. :}
kcassells
Hey Gimpy
what did you end up using under your fabric in the cabin? And did you use that plastic to make a template or that other stuff called scrim.
froggy1150
I used the scrim to do the patterning and put it up like an old car headliner. Its stapled all around the perimeter and across the roof braces. Also in 2 spots I have stainless rods holding part up. In those areas I stitched a sleeve for the rod to slide thru and there were holes in the wood that the wire slid In. Those were the 2 spots i started at. After it was all in i hid the staples with "hidem". There is spots where i used screws instead of staples for access panels for my roof lights that i do t like and plan to fix.
froggy1150
Here is the frame for my cuddy. Wog's Ole timers formula
