Thanks,Nice to see you got the old Holly out on the water.
Electrical issue like you say sounds like the battery is grounded to the hull.
Thanks,
So, I should probably create a main ground wire to the fuse block under the dash that runs back to the negative post on my battery, correct?
Oops, I meant to include a picture.Regarding my propeller having a chunk broken off, I'm thinking I should get a new one because if it is vibrating from being out of balance, that could be hard on the lower unit.
So, I don't care to go fast, so would a smaller prop, or less pitch be a good idea to lessen the load on the motor?
Your logic is correct; less pitch will get you out of the hole quicker at the expense of some high-end speed.Regarding my propeller having a chunk broken off, I'm thinking I should get a new one because if it is vibrating from being out of balance, that could be hard on the lower unit.
I'm thinking less strain for the motor will help the motor last longer.I'm not sure I understand why you want a smaller prop.
They may have some used in good shape props that you could buy at a reduced rate and return for a different one if that one doesn't work out.I know nothing about boats and outboards.
Thanks guys, I'll see what the local shop thinks.
I'll post back what they recommend.
