Hello,
Boat stop working over Memorial weekend and finally got some time to look why there were no sparks at the spark plugs.
Tested for spark at the ignition coil and there was no spark...removed ignition coil and retested with just a battery and manually toggle the 12V to the coil. No sparks with that method either...
Got new Ignition coil and cant get spark using just a battery and gap tester. Am I doing it right or you can't use this method to test a mercury ignition coil...
Attached a pic of my setup
===minus of coil to NEG of battery
=== switch from positive of coil to POS of battery
===bypassed ignition cable and attached gap tester directly to coil
=== ground other side of the gap tester
=== just meter to make sure everything is making contact
=== then I just toggle the switch to connect the 12V and I should see sparks but I dont
any thoughts to my setup, am I doing this correctly and the new ignition coil is bad also...please help
