if I can manually cause a spark, does that mean all the wiring is OK....the kill switch and wiring is OK ????sorry to complicate my issue with a bench test...anyhoo, followed yalls recommendation to put back into boat and follow flowchart
got 12V coming out of the module, then rapidly strike the GRN/White wire from module to GND, got sparks out of the ignition coil...YEAAAAAA
Looks like the issue is with the sensor, reconnect the GRN/white wire and turn the engine on, no sparks
I'm just curious, where does the kill switch wiring go to, tried to trace it on the boat but too many wires and long
