shsmith5595
- Jun 29, 2022
- 16
My trim up hasn't been working so I jumped the hurdle yesterday of replacing the trim switch on the motor. Trim sensor was working but I replaced it as well while I was in there. Everything worked good, trim and gauge were both functioning properly. Fired her up and went for a spin, came back and noticed a funky burning smell coming from the compartment. Tried to fire up the blower and it wouldn't come on. Turned the key back on and got a rapid beeping alarm. Still no blower. Turned back off and back on to no beep. Turned off the batteries at the perko and let it sit overnight to cool and went back down this morning. Blower still wouldn't work, first key to on turn had a faint beeping then nothing.
Checked the blower breaker at the dash and it was tripped. Reset it but still no blower. Gauges on the dash also appear to be inaccurate now--no battery voltage, gas gauge isn't where it should be, trim gauge partially works but isn't accurate. Motor won't crank at all. My guess is that a wire got moved into a hot spot and melted after I replaced the trim switch and sensor. Looked all through the motor and couldn't see anything obviously melted or out of place. Checked all the fuses by the 50A and they were good. Tried to press the 50A breaker on the motor but it wouldn't budge.
Any suggestions on what I might have messed up? I've got a voltmeter but I'm not sure where to start to begin tracing back to locate what the issue is. Motor is a Mercruiser Gen V 7.4LX Bravo 454 MPI/EFI on a 1996 Searay 28BR.
