smorrongiello
- Aug 20, 2022
- 15
I have a 1995 Evinrude E40ELEO, 2 cyl, 2 stroke, Electric start, electric T/T.
I just hooked up a VDO speedometer with the OEM harness that plugs into the OMC control box.
What should be the normal idle RPMs and what is typical max RPMs?
I have been idling about 1200 and WOT about 7000.
I am hoping the DIP switches are set correctly. There is conflicting information I found that states my charging system is a 10 pole or 12 pole. want to make sure I set the tach correctly.
Thanks!
Thanks!
