Jprevat
- Apr 25, 2016
- 321
Hey yall,
I am having a problem with no fire on my top two cylinders on the port side of the engine. I tested the ohms using the CDI website for reference. Everything checks out as it should except for the ohms between the red/black stator wire and the blue. CDI says that oem should read between 65 and 130 ohms, but I am seeing 24. I ordered a used stator from Strouds Marine to see if I could have an easy fix but it tests exactly the same at 24 ohms.
Am I missing something or did I receive a bad stator that is messed up in the exact same way my current one is?
If anyone can verify these oem values I would be extremely grateful.
