tannergallant123
- Jun 21, 2023
- 46
Hi guys,
I have a 1972 mercruiser 120 Hp 2.5 L boat I decided to restore a couple years ago. The engine got fully rebuilt. Couple things I’ve replaced when it wouldn’t run.
-a new replacement carburator from Amazon (2 barrel) with electric choke
-new mechanical fuel pump
-in-line fuel filter before the carb
-changed oil and oil filter
-distributor had so much play in the shaft that the rotor was hitting the distributor cap so I replaced it with an original one with no play from nla marine
-new cap, plugs, points and gapped correctly
-new starter
-new ignition coil
It’s just been an ongoing thing where one thing breaks down after another and I’m at the point now where I feel like everything is replaced and it still doesn’t run good. It only seems to start up and idle nice when it is too far advanced (turns over rough but when it idles it idles good but seems high). If I try and back off the advance it doesn’t seem to run nice which is why I have it advanced. The issue I’m having now is it will run good (around 30 mph) but when I go to idle it tends to bog out and then it’s hard to start even if it wants to start at all. I thought maybe water got in the gas so I put some sea foam and gas line antifreeze in and the issue doesn’t seem to be fixed. When I got rid of the automatic choke because the new carb has electric there is now a threaded male fitting that doesn’t have anything attached to it. Does this need to be plugged? Do I have a vacuum leak possibly? Running out of thoughts. Also my mechanical fuel pump has 3 ports (one for in one for out and one for a return). I blocked off the return end with a bolt in the tubing. Does anybody have any input on where I should go from here or things to check to get it running? Any help would be awesome.
Thanks
-new starter
-new ignition coil
Thanks
