Scott06
- Apr 20, 2014
- 7,401
Float and needle and seat are probably hung up or not put together right, also measure fuel pressure. if too high bowl will over flow. When running look down the bore to see if fuel is weeping into bores off boosters at idle.Okay now what would cause excessive fuel? Maybe just the new carburator I bought off Amazon is junk?
If plugs are black just getting too much fuel, more advance probably needed to ignite.... Should run near the factory initial timing spec
If you can rebuild a carb you are probably better getting a quality (aka not amazon) rebuild kit and doing it your self. Mike carb parts has good
