- Jul 23, 2011
- 50,897
good advice here.I would have put a Roller Cam/Lifters in,
Would that work with the non adjustable rockers?good advice here.
should, however you would have to look into the proper push-rod length.Would that work with the non adjustable rockers?
not with the conversion kit.The stuff I read online made it sound like converting to roller cam required block modifications.
Haha yeah a bit of mood lighting with mixed deck and engine room llighs.That blue/purple lighting looks really cool. I assume that you will be running with the engine hatch open just for visual effect.
Not sure if it was covered during this thread, but I assume the engine is a gen 5 454The gen 6 had the roller lifters and may have avoided the issue.
My main concern about the in-boat repair is/was the ability to get any/all metal shavings from the cam shaft/lifter out of the engine. Hopefully you've got that covered.
Yes, lifters came with new camshaft. Coated them in Driven Assembly lube.May have missed it but I guess you changed all the lifters.
