Hello All. New to the forum. I have a few questions and looking for insight.
Boat: Glastron Sierra w/ VP AQ131
Pulled it out this year and ran into spark issues. Got it fired up once and started to miss fire after 10-15 minutes. Proceeded to clean points, cap, and rotor, as well as check spark plugs and wires. Ended up ordering a replacement set of wires as the ones that were there were original and quite crispy. After cleaning everything, the engine would fire but wouldn't start. After more diagnostics, I determined that both my batteries were bad, due to the fact that I would drop well below 10v while cranking (which were suspect last year, even though I made it through the season) so I replaced both. I also found a crack in my distributor cap, so a new tune up kit was ordered.
Now, this is where I need help:
While waiting for my new cap to come in, I was checking the points to ensure there was spark. To my dismay, there was none while opening the points. I then verified that there was 12v at the distributor (purple wire), which there was. I pulled the coil to verify OHMs and had zero across the primary and 9ish on the secondary. I am in need of an aftermarket part number for a coil that I can purchase from a local auto parts store. From everything I've read, they are an internally resisted 3 ohm coil. I have searched and can not find an external ballist resistor in my engine, which is why I tend to agree.
Also, while messing with everything, I noticed that while the purple wire was connected to the distributor, my voltage on my volt gauge would drop to about 11.5v. If I disconnected the wire, it would just back up to 12.3+. Anyone have any thoughts or is this a result of the bad coil?
P.S. I've done a few keyword searches of the forums and have not found any info related to my specific issues. Thanks.
