Nope,...... I know of no differences, unless the u-joints or something changed,.... but that's only a guess,....Hey @Bondo can you help
I think this is when they changed the input shaft bearing set up from tighten nut to torque to to the rolling torque so would suspect the inout yoke bearings are different.At some point I think they went to different u joint bearings using internal clips iirc. I thought it was earlier than that though. @Scott06 was the one that posted the moog cross reference?
The rolling torque change happened with the gen 1's, but the ujoints were the same for all of them. Pretty sure all the gen 2's used the rolling torque.I think this is when they changed the input shaft bearing set up from tighten nut to torque to to the rolling torque so would suspect the inout yoke bearings are different.
