It was hard to tell honestly. I think it may just be from the fact the plugs have been in there since october 23 and the engine sat in the damp garage while I rebuilt the boat last year. Or my riser extensions are weeping. Actually no, as that would hit all 3 if it weeped.... I will also add, that is the riser/manifold side that runs warmer (alpha problems lol)Are the center electrodes on #s 2 & 4 showing some rust near the base? They are right next to each otherā¦.
It was a different gauge than I normally use. My matco gauge is usually 135 but it leaks down so you need two people. I borrowed my cousins horrible freight gauge and got those numbers. Throttle was open. I bet if I used a longer adapter (more in the chamber like the long reach plugs vortec heads use) it would've been a few points higher.Well those are very consistent, no water out of the plug holes?
I think youāll see higher #s with a hot engine & wide open throttle. Mine was 160-170 but again might just be gauge differencesā¦.
Nothing out the holes plugs stayed dry. I did dump the fuel filter... some silt in it but nothing crazy. Looks mostly like remnant glass from the tank being in the garage... no water there either. Going to start a leakdown.I have a Lisle gauge, every time when I've checked the compression it's always about the same. No water out of your plug holes? Just wondering about what the plugs from #s 2 & 4 looked like....
You have an inspection camera, might be good to take a look inside...
125 is good enough to run, and very even. seen much worse variation run just fine. As long as the plug seals the length of reach wont matter -Dont over think itIt was a different gauge than I normally use. My matco gauge is usually 135 but it leaks down so you need two people. I borrowed my cousins horrible freight gauge and got those numbers. Throttle was open. I bet if I used a longer adapter (more in the chamber like the long reach plugs vortec heads use) it would've been a few points higher.
One other interesting thing, this engine always had a "skip" cranking. Its not like a bum cylinder skip. More like a improper starter shim skip. It does it with all the plugs out even.
And it runs well. Pushes my sled of a boat to 44mph give or take and is snappy. Not reading into it!125 is good enough to run, and very even. seen much worse variation run just fine. As long as the plug seals the length of reach wont matter -Dont over think it
My machinist had to take it .060 over.Interesting, the one thing that jumps out at me is some rust on a valve in cyl #5, but that might be nothing, and a bit of scoring in some of the cyls, again, if blow-by is normal might be nothing.
This was a re-man engine correct? How many thou was it re-bored?
I have those.What might be interesting is to do a cylinder balance test. See how much the RPM drops while disconnecting one plug wire at a timeā¦..with insulated pliers of course![]()
