cyclops222
- Mar 21, 2024
- 2,660
How much leakage can really happen when the cylinder is firing 12 times a second ? At 600 times a second ?
I would run it as is.
1 jet 2bbl mercarb. I have a 4bbl weber sitting on the bench to go in... once this is figured out for good.Old boats with carbed engines are just prone to these kinds of things, can't hook up a scanner and read live data!
I agree I would run it, if the missing comes back, do a cylinder balance test....
Is the carb a 4bbl? Weber or Edelbrock? In which case it is pretty easy to take off the air horn to see if there's anything floating around in there...
Its a merc weber off the same engine set up to the factory specification. Having had them all, for this application I'll take the weber.You are aware that true Weber carbs used to require a LOAD of different liquid & air jet sizes to get them tuned correctly. It is a slow & tedious procedure. Unless things have changed.
Weber's make great paper weights.
