cyclops222
- Mar 21, 2024
- 3,218
How much leakage can really happen when the cylinder is firing 12 times a second ? At 600 times a second ?
I would run it as is.
1 jet 2bbl mercarb. I have a 4bbl weber sitting on the bench to go in... once this is figured out for good.Old boats with carbed engines are just prone to these kinds of things, can't hook up a scanner and read live data!
I agree I would run it, if the missing comes back, do a cylinder balance test....
Is the carb a 4bbl? Weber or Edelbrock? In which case it is pretty easy to take off the air horn to see if there's anything floating around in there...
Its a merc weber off the same engine set up to the factory specification. Having had them all, for this application I'll take the weber.You are aware that true Weber carbs used to require a LOAD of different liquid & air jet sizes to get them tuned correctly. It is a slow & tedious procedure. Unless things have changed.
Weber's make great paper weights.
The Merc Weber 4bbl was not a traditional Weber but a refresh of the old Carter 4bbl. I know of the ones you’re referring to lol!You are aware that true Weber carbs used to require a LOAD of different liquid & air jet sizes to get them tuned correctly. It is a slow & tedious procedure. Unless things have changed.
It is a Rochester, just with one idle jet instead of two. But I also have the 4bbl and intake ready to go. Sorry for any confusion.I thought the Mer-Carb 2bbl was a modified Rochester 2GV (sure looks like one) whereas the Weber 4bbl is an update of the old Carter 4bbl used on many Chrysler products and the Edelbrock is very similar if not identical to that....
I have a Quadrajet on mine now that needs a cleaning and rebuild and I also have a Holley 4160 calibrated for this engine sitting on a shelf in the garage, and believe it or not I just bought an Edelbrock 1409 as well. So if one carb gets gummed up and can't be made to work right due to dang ethanol gas I have options.
BTW, here's an idea for those of us in draconian states that force you to use E10. When winterizing, how about filling the fuel/filter separator with straight gas like VP Racing, etc, and then run the engine on that to fog it? That way the E-10 isn't sitting in the carb all winter. The ethanol related deposits and the deterioration of rubber parts seems to be what causes most of the problems with carbs and E10. My fuel is always totally clear when I dump the filter though.
Agreed the webber edlebrock is easy to tune if you have some background in it. If you have the factory webber put that on and see if the issue goes away.Its a merc weber off the same engine set up to the factory specification. Having had them all, for this application I'll take the weber.
The rochester with one idle jet (screw?) is a mercarb. Merc made their own after GM stopped making 2 jets in late 80's or 1990 ish. Obviously a common lineage to the 2 jet.It is a Rochester, just with one idle jet instead of two. But I also have the 4bbl and intake ready to go. Sorry for any confusion.
Honestly, I've only had 1 ethanol related issue on any of my boats and it was caused by being laid up for 2 years. Splash of stabilizer at the end of the season on the last run and when fogging the engine purging the bowl vent and filling with fogging oil has kept me from needing to touch any of my carbs for like 20 years now. Same with the lawn equipment. It is an issue, but much like anything else, proper preventative maintenance goes a long way.
