cyclops222
- Mar 21, 2024
- 3,218
There is a Deka battery company. They use 98% recycled lead in the battery.
There are no virgins in the battery world.
I have two EverStarts either 24 or 27's. I've had good luck with them over the years. I have the second one in the boat as a backup in case something happened on the lake. We just recently got back from a fishing trip in Quebec Canada. It's pretty remote and I wanted the redundancy for safety.Buy a big... Master Battery Switch......It has #1..#2..Both..Off Positions. Install a standard sized car battery. Size 24 or 31.
Interstate was running a factory sale at a local store of theirs. $124 ? Marine Terminals on both posts. Has car and threaded posts. Done Battery is 1 month old and fully charged.![]()
Yes, I just realized I said series. I meant parallel and was coming back to edit.Wiring in series was wrong. They are to be connected in parallel.
In series they develop 24 volts. That would / could damage electrical parts. You might be the luckiest boater around.
Most major car battery brands, such as those made by manufacturers like Clarios, East Penn, and EnerSys, use high-purity "new lead" in their lead-acid batteries, although the exact sourcing and composition varies by manufacturer and product line. Retailers like AutoZone (Duralast, Valucraft), O'Reilly (Super Start), and DieHard are often supplied by these large manufacturers, selling batteries under their own private label brands.There is a Deka battery company. They use 98% recycled lead in the battery.
racerone it isn't even with the new parts. 12.48v is as high as I'm reading.Voltage at the battery should show about 13.5 volts at 3000 RPM
Also to note, all the connections are clean.Voltage at the battery should show about 13.5 volts at 3000 RPM
Always buy oem if available.racerone it isn't even with the new parts. 12.48v is as high as I'm reading.
Jeff
Yes, had I known I was buying Sierra parts. I would have absolutely bought OEM.Always buy oem if available.
I will try to trace it down.Something is wrong if you are not seeing 13.5 volts at cruising speed. !!
As long as it's a lead acid battery your fine. Battery voltage is slow, clip your meter onto the battery and run it around for awhile and see if it goes up.@racerone, everything checks out to be in spec.
I need to get the boat in the water to test at upper RPM's.
Outside of that, any ideas as to what the issue could be?
I am running a maintenance fee battery. Could that be the issue?
Jeff
The above readings were at the motor as well as the battery. Same reading everywhere I measured from the rectifier/regulator to the battery.Check if in the boat the battery peaks at about 13,7 vdc or 14. 7 vdc .
Do you play loud music with or without the engine running ?
