crazy charlie
- May 22, 2003
- 5,670
It's on there for an unexpected current surge. If that happens the internal circuit breaker opens. As alldodge said, the button is to reset it. Before you go to a lot of trouble push it and see if it resets. If so, fine. If not one of 2 reasons: Broken internal switch, or continuous current overload.Thanks guys ,will do.Pressing the red button is basically a reset??
Thanks, kinda weird that all was fine when winterized and it's just been sitting. Puzzling but will check .Thanks CharlieIt's on there for an unexpected current surge. If that happens the internal circuit breaker opens. As alldodge said, the button is to reset it. Before you go to a lot of trouble push it and see if it resets. If so, fine. If not one of 2 reasons: Broken internal switch, or continuous current overload.
Yes, but keep in mind jumping it with bad connections may not change anything if jumper does not make a good connectionWould jumping the breaker confirm this is the issue as well or is that a bad idea?
