Crazy_Pilot
- Oct 27, 2017
- 35
A tale as old as time. Man see boat, man buy boat, man discover soft floor (6 years later), man ignore wife suggestion to buy new boat, man get itchy arms.
Back in 2018 we picked up an Arriva 2050 with a 5L and have enjoyed it well since then. It's had a couple issues but just normal boat stuff. Last summer when I hopped in I felt the dreaded softness underfoot and knew the time had come. The boat isn't a trailer queen, it goes into the water in May and comes back out in September/October, so it deals with all the elements. The cover on it is new and works well but nothing is perfect, and the 29 years before my ownership undoubtedly had their periods of neglect.
The happy times at the dock:
Some experimental prodding at the soft spot revealed a bunch of sopping wet mush under a thin coat of CSM. This is of course where you step down into the boat so years of people hopping in were taking their toll.
The first cuts into the foam revealing a nice puddle underneath. Maybe I'll get some goldfish.
Time to start the demolition in earnest.
The boat has raised floors on with side of the main engine compartment. The port side was not so bad but the starboard was utterly trashed. The battery box had been screwed down to multiple locations over the years and the inevitable happened.
Moving forward to the rest of the floor. Discovered the fuel tank is just held in with great mounds of CSM.
The fuel tank compartment was delightfully slimy. It has a small raised floor that was only glassed on the top side, and of course water from the ski locker is allowed to drain through this space. The result of which is wood here being basically wet sawdust in a vaguely board-shaped form.
The bulkhead between the ski lockers and tank compartment after I stepped on it:
Next up, engine removal and transom.
