Changing colour of gelcoat question
MikeSchinlaub
Would 2 layers of 1.5oz chop strand mat with 17oz 0-90 glass in the middle be strong, light enough.
Hmmm, maybe. It wouldn't give you much material for attaching hardware though, and you wouldn't be able to staple the upholstery to it. I would still suggest using a core material of some sort.
Is the idea to not use wood to avoid rotting?
carlos515
Not really, I was just thinking of a clean interior. Maybe I will laminate 2 of my panels together. That would be close to 3/8 thick. Then skip the fibreglass and use my foam and vinyl. Just thinking of different ways to finish the interior.
carlos515
I forgot I made gel coat laminates for the top of my sides many years past.
Never thought of PVC sheets. They may be good for the bottom of my sides.
carlos515
My youngest son came up with an idea for seating. I was just going to put a big sun pad at the back. Now I made a frame for glassing. I used exterior plywood. I will have to seal every square inch with resin. I still have to price the pvc sheets tomorrow. The front Port box seat will have a flip-flop back rest to watch the tubers, skiers, etc
carlos515
I just priced some 5/8 Meranti marine ply,156 a sheet. For the peace of mind, I think before I do the other side, I will get a few sheets of it.
Edit: Would 1/2 inch be ok if it is glassed?
carlos515
I can re-use my old seats for the rear anchored seats. I have new vinyl skins made for them.
