1060 Evinrude fisherman 5.5hp
puffitu
Hey all
I’ve recently acquired this vintage 5.5hp and after starting to comb through it, I came to a halt after trying to drop the lower unit for inspection. Is there a pin or some trick to release it?? Seems stuck. Thanx
Crosbyman
you will have to remove the power head to access the shift under under it ... not as big a job as it seems 7 screws a few hoses and side side throttle post
see video
change the impeller ... !
if you are careful you may be able to save the main gasket under the PH otherwise you can order it from Vintage outboard .com
313065 gasket, base for Johnson/Evinrude 5.5hp 1959-64 – VintageOutboard.com
dont mix the gaskets .... patterns differ match old and new
great motor btw.... respect oil/fuel ratio recommended
puffitu
see video
Great info; thank you so much!
puffitu
puffitu
Need torque sequence for re assembly of power head if anyone’s got ?? I’ve replaced the impeller -not much to it at all..
Crosbyman
see pic and yourengine type... CD sequence figue 8 to spread the load on the cyl head
retorque after a few hours
puffitu
Is there a start up procedure I should adhere to after putting it a together; replacing impeller, head gasket, thermostat, fuel lines, carb kit, plugs…? I’ve not done points or changed the plug wires at this moment
oldboat1
Think I would clean the points, at least, before trying to fire it up. Use a piece of cardboard (matchbook cover or similar), dab some acetone or lacquer thinner on it (brake cleaner maybe) and run it through the points a couple of times.
Crosbyman may have some thoughts.
puffitu
Thanks-I was thinking maybe to wrestle the flywheel off in the morning and have a look. I have a puller; just don’t know how easy it’ll come off. Don’t think this engine had seen any salt water but still
oldboat1
grade 8 stainless. Can use a harmonic balancer puller. Leave the nut on about half way for protection (you and the shaft). Whack the center post a couple of times with a 2lb sledge, tighten and repeat if necessary.
I normally just use some old head bolts from a 5-1/2 or 6 HP to pull them on small motors.
puffitu
FF21B2FF-4691-4A43-BCDD-2C90C8745093.jpegIs this key 1. Sheared and 2.Is it supposed to be loose ??
F_R
No, not sheared. No, not supposed to be loose in shaft.
