1060 Evinrude fisherman 5.5hp
Crosbyman
puffitu... you really need a book to chase all these issues 60 posts on a 5.5hp must be a record :)
join up AOMCI and get yourself a free copy of the johnson maintenance manual downloaded form Garry Spencer's drop box. it is free to members
it is a 691 page book covering oldies from early 40s to late 50s
puffitu
Ok so…the leak was a separate issue due to the oil seal which I replaced and holding pressure now. The hard rotation of the shaft was due to the spring being fatigued which sits atop of the drive shaft; it keeps downward pressure on the shaft into the shock absorber-my diagnosis thus far. Will update once started again
puffitu
Well I appreciate the recognition for a record set, and all the patience and advise from all you folks. I will down load this thank you
