2000 15HP JOHNSON (2 STROKE) ONLY FIRING ON 1 CYLINDER, I think.
It's running rough and poor idle. I have to baby the throttle, or it dies out. Seems to run ok at high rpm's, but just not right. Runs ok on land, but poor in water.
So with motor running, I pulled one plug wire at a time. When I pulled the bottom wire, the engine kept running- replaced wire. Then I pulled the top plug wire, engine stopped running.. From what I've read, that means engine is only using 1 cyliner.
I swapped spark plugs and then I swapped plug wires. Same result on same cylinder. I then crossed the the plug wires-- top to bottom and bottom to top (at the spark plug), same result on same cylinder.
Compression in each cylinder (111 and 110). I can see spark on both plugs.
Is my coil bad? Thank you for you help!
