country boy
- Dec 20, 2002
- 61
hi, recently posted topic ,on this so not sure where to start so , my 175 was running ok then it seems that out of no where i am running about 5200 rpm to my spot ,it missed a little slowed down then took off ok then stoped for awile ,went to take off could not get up on step infact could not get over 1800 rpm, brought to shop ,.has had all the electronics changed and tested,mechanic said every thing checked out ok except (tps)set to specs did not fix problem,he said that i had some parts missin from efi a filter under cowl and soms trash may have got in injectors ,and said it would be more than it was worth to fix efi,susested that i convert to carbs ,is this something i should do ,what are pros & cons, or should i look into fixin the efi system, this is a certified merc dealer any input would be helpful . Than
ks
