Re: 175 Johnson Fast Strike
OMC started the "saltwater series" type of outboard back in '93 and yours is a '95, so you have the extra corrosion protection on it.<br /><br />They are good outboards, just be sure to use Champion QL78YC plugs only, gapped at .030", and make sure the thermostats are clean and operational. Prop the engine to run close to 5500 rpm with an average load. That 60 degree block has a good reputation for reliability. If it hasn't been serviced recently, make sure to put a new water pump kit in it, #5001595.<br /><br />Like any used purchase, have it inspected by a QUALIFIED tech.
