HighTrim
- Jun 21, 2007
- 10,486
Re: 1957 35 hp Johnson seahorse won't start
Well pull the head first and have a look at the gasket and the cylinders, post pics if you can.
If it is just a head gasket you are in the clear. Dress the head before installing the new gasket as follows. Also ensure you use the proper torque in the proper sequence. 220 inch/lbs....start at 110 inch/lbs for a rotation, then about 165 inch/lbs, then the full 220 inch/lbs.
