1946Zephyr
- Oct 21, 2008
- 5,556
Re: 1957 35 hp Johnson seahorse won't start
If the scratches are light, you'll be fine. Luckily you were able to get the cover off, without breaking any screws. It must be a fresh water motor and never been in the salt. I would completely clean the threads on the block and the screws, before you put the exhaust cover back on. That will make it easier to remove, sometime down the road. Earlier this year, I bought a nice looking '57 Big Twin and when I brought it home, I checked all the screws in areas like that and luckily nothing was stuck. One thing that typically gets stuck are the two little screws on the sides, that hold the lower shroud haves together. These are located right near the shifter and the vertical throttle advance lever.
Keep up the good work. I believe that motor will be a good runner. Thos old 35's are very forgiving and come back to life pretty easily. Check that little rectangular passage and make sure that it's not crushed. If it is, then you will need a replacement head. Chris will likely have one if you need one.
Thanks for all of your help. One more thing. When I opened up the exhaust cover there were som scratches on the piston. Does that matter?
