model # 7522, 7.5 Evinrude.<br />Just resealed the lower. When I tried to turn it by hand with the driveshaft, it will bind up for about 1/2 turn, then free up, then bind, you get the idea.<br />I have a factory manual, doesn't really address this issue, I searched the forums, didn't find anything. I also took it apart again, took the gears out and tried to turn it. Same thing, it would appear to be the pinion shaft. The water pump was not installed . Any ideas? I don't remember it doing this before. Is it time for a new lower?<br />Thanks.
