HighTrim
- Jun 21, 2007
- 10,486
Re: 1957 Fastwin - Restoration consolidated
So that gearcase doesnt have the phillips head pivot pin on the right side of the gearcase? Your '57 Fastwin should not have a phillips head pivot pin. The '58 Johnson FD12 18hp will have one though.
Some of those holes are drain holes, to keep the gearcase empty of water when you pull the motor out of the water. It didnt have that many originally though, nor that big!
EDIT: OK, I have 2 '57 Fastwins, 1 electric start the other manual. The electric start does not have the phillips head pivot pin, the manual start does have it. I think that was one of the mid year engineering changes in '57. The '57 Johnson FD series changed with the "K" suffix in the model number signifying the mid year change.
I dont think any of the 10hp motors had the pivot pin until '58, I dont recall having a '57 with one.
Perhaps Frank can verify that.
