1958 QD-19 Johnson 10HP cracked lower end help! Freeze Damage.
bigjo911
Re: 1958 QD-19 Johnson 10HP cracked lower end help! Freeze Damage.
The pivot pin screws through the outside of the skeg and into 47, right? If so then this is not the pin I'm talking about.
AlTn
that looks like the drive pin for the prop...are you certain it came from inside the case..or maybe it feel from the propshaft without you noticing it?
bigjo911
The skeg was not fully off when it fell out, so unfortunately I do not know where it fell from. I did place the pin in that hole in the prop and it seemed to fit perfect. The pin was covered in oil so I also thought it would have come from inside the skeg somewhere. Although now it seems to be the prop pin. Inside the prop is a place the pin sits. See the pics below. Is this it???
http://i791.photobucket.com/albums/yy194/myparttimebusiness/1958 QD19/DSC_0018.jpg
http://i791.photobucket.com/albums/yy194/myparttimebusiness/1958 QD19/DSC_0020.jpg
nwcove
i think ya got it. i read this thread and looked at all the links, couldnt see see where part #x fit into part #y, but now it looks right. and oil on that part/pin probably means you need a seal kit.
1946Zephyr
Ok, so 38 screws into the skeg and through 47. This I get - Pic
48 (Pin) is intact and has never moved. Pic
I placed the pin that fell out on 47 just to show it. Pic
Are you saying that there was a spare drive pin inside the lower unit?? :eek: Well, that's an interesting idea. I'll stash my spare drive pin in the lower unit, so I don't misplace it. :D:D LOL
AlTn
yes, the slot in the prop hub slides over that pin
bigjo911
LOL, If I only saw where it fell from the first time. I appreciate all the help fellas. Happy Holidays!
