1975 25 horse 2 stroke
jbcurt00
if I have offended anyone due to my innabilty to navigate this forum im sorry I had a stroke a year and a half ago and lost some cognitive thinking in other words when it comes to mechanics this motor would have been second nature now I have to reteach myself all over again I don't understand how to combine posts to make a thread and so many other things so please be patient
Not at all
You are doing fine
oldboat1
Yeah, all OK, rpm. Judgment call for moderators, but get tired of locating old threads to get background (pet peeve) -- wasted posts, repeated questions, lots of repitition. Happens a lot.
Anyway, there should be an idle screw adjustment on the side of the motor with the twist grip. It's plastic and might be red or white -- goes through a spring. This is used to adjust idle speed. On the other side of the motor there is the gear shift -- but think you might be talking about that idle screw. If so, what are you trying to do -- motor running too slow at idle after you start it -- stalling?
[edit. Throttle speed is set with the twist grip -- including idle speed. The idle screw is really just a set screw to keep the engine from stalling when you idle it too low using the twist grip. You can usually release the screw (counterclockwise) to the point where you can kill the engine with the twist grip, if you choose to do that. All of this works right only if ignition and fuel systems are operating properly.]
