glenn property of pam
- Feb 17, 2012
- 2,906
Re: 1975 Century Arabian - Total Restore
marksa you have skipped a few steps which is why you are finding that the hull is flexing. As you have already started and removed a lot of the internal structure I would leave the boat on the trailer and add extra 2 by 4 timber to give the hull more support to the trailer. It doesn't have to be pretty but it needs to stop the boat splaying as you are walking around in the hull. I personally would try to add wood so it acts like another set of bunks near the outer bottom edge of the hull and probably 2 pieces up the side of the hull.
The pictures look like the floor over the foam rotted out and was removed then new glass was layed over the old foam but I may be wrong. Take lots of measurements and pictures and just replace with ply then after they are fixed and glassed in drill holes and pour in foam. Looks like you are doing a good job so far
