I have a 1975 Merc 1150 that I bought last fall. I replaced the impeller, put it on muffs and turned on the water before starting it for the first time today. The pee stream started spraying water even when the motor was not running (not all the time but most of it). On my other Merc's the only time they would pee is when they were running. Is there something I could have done when I changed the impeller or is it normal for this motor to pee with only the muffs attached? Or is there some other problem?
