edgutgesell
- Jul 18, 2004
- 144
I have a 1984 Yamaha 150 v6 engine and for the second time in about 2 years the oil control unit has failed. The way it failed is that the main tank on the engine overfills by the pump in the sub tank not cutting off. I determined that the oil controller was the problem by grounding the white wire to the controller after disconnecting it from switch1 coming from the oil level sensor. Grounding that wire should turn off the pump in the sub tank and it did not, indicating that the oil controller is bad. Also, the blue wire going to the pump was not grounded which was the only other possible cause. I used the diagnostic explained in the Bass & Walleye Boats article "Slippery Solution".<br /><br />My problem is that the oil controller on my engine is an earlier model with different single connectors going to the oil level sensor and single pluggable connectors going elsewhere on the engine. I have found out that the earlier oil controller (6E5-85740-02-00) is no longer available and it has been replaced by 6E5-WS857-00-00. I ordered the newer controller and when I received it the connectors to the oil level sensor and elsewhere were different. The connector to the oil level sensor is a 4 wire plug instead of single wires and the rest of the wires from the new controller go to a 7 wire female connector. I have the Yamaha service manual for my engine and it appears that the only real difference are the connectors. <br /><br />Has anyone out there retrofitted the newer oil controller (1985 & newer) to an older engine? If so, are there any major problems involved in doing the retrofit? It appears that the color codes are the same with the exception of the wire to the CDI unit. (pulser coil) It seems to me that retrofitting the new oil control unit to the existing wiring on my engine would be much easier than changing my engine connectors to accept the new controller connectors. Is there anything I am overlooking??<br /><br />Ed G.
