Re: 1981 Evinrude 25hp Project Motor
Hi all, I took the carb off.
Also, I see some oil by the plugs, is that bad?
Also, in the carb the jet that is in the pic I am guessing that is the high speed jet? I cannot move it. Is it supposed to move? I also noticed that the tube inside is off center. Is this OK?
What about the little 'ring' above it with the slot in it, can I remove that?
I also noticed that the carb has 2 screws missing from the left side of it, so it wasnt even being held together properly, thats probably why I saw the gas leaking.
What am I supposed to clean here?
Check the pics, and let me know.
Thanks! Almost there!
