Re: 1984 Mercruiser 470 3.7L 180hp-Help!
The motor runs fantastic. Lots of power and in excellent condition, achris!
Ok guys, lots of corroded wires, broken wires, and all kinds of mess. Pulled all the wires out, gauges, etc. Got a volt meter and lots of connectors, dielectric grease, wire, etc. Got a new fuel tank sending unit (extreme corrosion), needless to say, now all my gauges work. What a job, but now all the wires are neatly redone and very easily accessible in the even of replacing something. I even replaced the MPH "fin", and tubing to the mph gauge.
The only thing that doesnt work is the trim gauge. Grrrr.
Now, on each sides of the outdrive on the "horse coller", there are small round plastic things with wires attached to them which is for trim position and trim limit. The wires were broken off, and I decided to go ahead and order new ones. Now, I'm not sure what wires to connect them to once I put them on.( I do have a green w/ white stripe and purple w/ white stripe wire coming off the wiring pack from the pump and gauge) And I'm hoping this makes my trim gauge work, as these wire are not hooked to anything. Green and white comes off of pump and purple comes from 4 stranded wires coming from throttle control. Also, my "up" portion of the swtich on the throttle doesn't work, only the down, but the "trailer" button (trim override) does work so thats how I'm getting it to go up. Could this be because of those trim position and limit sensors or could it be the switch in the throttle just doesnt work when pressed "up".
Anyone had this issue? I'm slowly working all the bugs out. I spent all weekend working on this thing, only spent $400 so far on parts, and got the boat for a good deal so I'm not complaining!
