I recently purchased a 1980 Wellcraft V20 Steplift with a 1985 Mercury 115hp I6 OB. It was suggested in addition to changing the lower unit gear oil and plugs (if they looked bad, and they did), that I replace the impeller.
The impeller swap wasn't all that difficult other than a second trip to the shop to pick up the impeller kit rather than just the impeller as the old impeller and the housing was in bad shape. The impeller was missing one vane completely and a second vane was ripped in half. The mechanic asked if I was able to get the pices of rubber from the impeller out from inside the engine. He could tell by the look on my face I had not and when I asked how I checked he suggested I bring it into them to check.
Since I had already lost two weeks since I bought the boat having all the 30+ year old fuel lines replaced with new for fear of getting stranded out in the bay with ethanol damaged rubber hoses. I thought I would tackle this one myself.
I cannot seem to find a thermostat on this engine anywhere so I'm thiking there isn't one. It appears I may have to remove the engine from atop the drive unit to access the lower water jacket bolts. Is this correct? Or is there a way to sneak the lower cowl down/up or around to allow access to these bolts? Seems kind of silly but one never knows unless ya ask.
Thanks in advance for the help.
Steve
Steve
