Re: 1986 225HP V6 Looper Hard starting, bogs, stalls
OK Here's where I'm at now.
I knew I had one cylinder not firing or firing intermittently, so I decided to fix that first, as it was the easiest to troubleshoot. Without going into all the details, it turned out to be the stbd side power pack intermittent on the top cylinder. This made a very minor improvement in how it ran.
I checked the link and sync, and everything looked good, but I went though the adjustments anyway. No change
I had changed the fuel pump from the three wire to the four wire pump before I launched the boat. I didn't think the pump was bad, but just to eliminate it as a possible cause, I swapped it with a known good fuel pump from the 1988 that I had removed for this engine. Also checked all the fuel line connections in that area. and everything was good. No change
As I had mentioned earlier, the carbs had been pulled and cleaned previously, but I wanted to get a better look at all the connectors and fittings, so I pulled them with the throttle plate assemblies attached. The only thing I found was the plug for the test port on the intake manifold was deteriorated. It was hard and cracked, but was still in place, so I don't know how much air could be leaking past it. I did replace it.
After finding very little that I could point to as causing the problem, I made a decision to try the carbs from the 1988 engine. They do not have the smaller bore diameter that the 1987 carbs have. I didn't have an accurate way to measure them, but as close as I can tell, the bore diameter on the 1988's are the same as the 1986"s. The orfices are different though, along with any other changes, that I'm not aware of. The engine runs much better, although not 100%. The engine will some time start as soon as I hit the key, and other times it will not. I can always get it started now, but sometimes I have to put it in neutral, and advance the throttle to get it started.
It will ocassional bog and stall, and that only seems to happen if the engine sits for fifteen minutes or so. It acts as if it just runs out of gas. If I work the throttle as it's dying, I can see the rpms pick up for a split second, but it just contiues to die. I did check the primer bulb on the fuel tank and the ball stays hard so The check valve seems to be good. I can then restart it let it idle for a minute, and it will run like nothing is wrong. At least I can use the boat.
I tried ajusting the idle timing and the cam follower to see if I could get it to start better, but neither thing had any effect, so I put them back where I started. Idling in neutral at the dock (which is not the proper way to check the timing) It is 6* ATDC, at 650 RPM, and it seems to run best at that position.
It was brutally hot this weekend, so that's as far as I got.
