1987 Sea Ray Seville "Re-Re-Restoration"
Status
Not open for further replies.
kabookey
Re: 1987 Sea Ray Seville "Re-Re-Restoration"
I found what appears to be some kind of bracket in the bilge; does anyone have any clue what this could be for?
Figured out what this was for; its the bracket for the tow-rope hook.
kabookey
Some updates:
Worked on removing part of the transom; cut out the skin, pried away the glass, and chiseled out the wood with a painters 5-in-1 tool (this tool is amazing for just about everything; chipping out wood, cutting away foam, etc.)
After I cut out the transom and removed the foam, I stumbled upon this; speedo lever screwed right into the hull. Nice.
Cut out the other engine mount (there was some solid wood this one.)
Finally was able to remove the Y-Pipe & housing from the transom (needed 12pt sockets which of course I did not own). Got the hinge pins out with a 1/2" allen wrench, 1/2" impact socket and a breaker bar (no heat needed, came right out.)
Next on the agenda is gutting the remainder of the transom, get her grinded (is that a word?), and make a template. I am going to make the new transom span the length of the hull instead of the Original 3pc design; I figure that will make it just that much stronger. I will hopefully have some updates for you in the next few days.
SDSeville
Much thanks! There is just something about these older model Ray's, they have this "timeless" factor to them if you know what I mean.
I agree -- love mine. I think I will tag along on this one. Good Luck kabookey!!
hsr65
Another buddy of mine found these Chaparral seats in the trash (yes, the trash) and gave them to me for free (any good suggestions for cleaning these things please let me know).
I've been using LA's Best from Dollar Tree. The yellow stuff with a short stiff bristled brush. Wet the vinyl with a hose and then spray on the cleaner. Let it sit about a minute and start scrubbing. Some spots needed to be gone over twice. My interior looked similar to your pictures and for my boat being a 1989, the original interior looks almost new again.
kabookey
Excellent, I will have to give this a shot. Thanks for the heads-up.
buzzcut55
Some of my progress thus far; deck removed, hull partially grinded, engine pulled. I plan on finishing up the grinding tomorrow so I can start cutting out the stringers.
hello. i just had to join the forum so I could talk to you .yours is the same year and make as my project , except mine is a cuddy cab. I am still tearing mine down looking for all the rot . not as bad as I first thought . I see you haven't posted in awhile , would like to hear from you. thanks. kc.
mwe-maxxowner
Master Chief Petty Officer
I like that boat. I have a friend with one identical he received in a trade, in similar condition. I've been talking him into restoring it and making it a setup for lounging around and relaxing, as we already have two to ski from and he has no money in it. I'm watching this one!
kabookey
Hello all, its been a few since I have posted. Seems Florida and its erratic weather have plotted against me and my build; a 5min mini-hurricane flung my canopy over the fence and into the neighbors yard (I bought him some beer, he forgave me.) I have, however, fixed the canopy and have been finding a few hours here and there to get some work done. I am hoping to have a status update and some pics posted tonight.
kabookey
You never know what you will find until you start to grind....
kabookey
Here she is with all the wood and glass removed. There was some NASTY stuff in the drain well; oil, leaves, and to my surprise, a family of cockroaches. I let the muck soak in some ZEP degreaser then blasted it with a pressure-washer, came right up.
kabookey
For the transom, I made some clamps out of 2x4's and some all threads and bonded together 2 layers of 3/4 treated ply. For my first (failed) attempt at this, I used the fast grab PL since it claimed it was 8x stronger, but I had a very hard time even getting this stuff to come out of the tube, and no matter how much I clamped it down I could not get the pieces to bond without a gap. I don't know if I got a bad batch or what, but regardless I had to start over from scratch. My second (successful) attempt was with using the regular PL premium. If anyone has had any experience with the fast grab please feel free to chime in.
I was originally thinking about doing the transom as one-piece but decided against it for a few reasons; first, I wanted to keep the design as close to factory as possible. Second, since the swim platforms screw through the sides, I figured this would minimize any possible water intrusion into the main transom.
The center transom was adhered with a mix of resin, milled fibers, and cabosil, filleted with the same mixture and tabbed with 1708. After it had cured I realized I had some bubbles so I ground down those areas and re-tabbed.
After completing the initial buildup on the transom using 1708 and 1.5oz mat, I filleted the engine stringers in place using epoxy* and glued in the side transom pieces and clamped them down.
And here is the transom completely covered in 1708 and some 1.5oz mat. To make sure I was within factory specs, I used a digital caliper around the keyhole to ensure I was within an 1/8 deviation. When all was said and done I believe I was right at 2.25".
*I decided to use epoxy for the fillets (and eventually the tabbing) on the engine stringers thinking structurally it would be stronger, but did not put any consideration into how difficult it would be to keep the divide between the epoxy and polyester. After cursing myself out for this rookie mistake I grinded out all of the epoxy and re-did with polyester.
kabookey
Originally I had planned to complete everything below deck before re-installing the engine, but due to the sale of my friends house (where my engine currently resides) that was pushed to the front of the line. Just wanted to give a heads up in case any of you were wondering why I am throwing the engine back in before finishing the stringers, bulkheads, etc. etc.
For the stringers, I went with 3/4 ply filleted in with PB. I decided to use the stagger and butt-joint method to create the full length stringer.
kabookey
For the engine mounts, I did not want to use lag bolts, so I went with this design instead so I could use through-bolts; 2 layers of 3/4 ply bonded with PB and stainless screws.
Here are the mounts filleted in; had to de-burr a few strands of errant glass and grind down some bubbles, but for the most part I am happy with the way these came out. To finish these I tabbed in with 1708 and covered with 3 layers of 1708, and I will be posting those photos in the upcoming days.
kabookey
To drill the holes for the transom, I used a drill-press attachment and a brad point drill bit. The way the attachment was engineered, there is a groove on the bottom which made it difficult to get it to lie on a flat surface, so I screwed some scrap wood to the bottom, drilled out a hole in the scrap wood with a 1" spade, and used clamps to hold it still. Honestly, this part made me very nervous; any deviation in these holes can cause issues with reinstallation of the housing, but the press did its job and the holes came out perfect.
kabookey
Thank you sir!
mwe-maxxowner
Its lookin' like a real nice build.
kabookey
Good New Year to you all. I figured it has been entirely too long since my last post so I would throw up some updates. Since I last left you, I have gotten made some huge progress. The deck is (almost) done (minus the final piece at the rear), the helm pieces have been constructed, and currently I am working on the bow and the speaker box.
Now, on to the pics. Here is the cut bulkread ready to be installed and the first stage of glassing in the stringers; I rounded off all the edges, tabbed in with 1708 and put down 2 layers of 1.5oz CSM. Note where it looks slightly bulky is where I joined the stringers via butt-joint (2 1/2" pieces of plywood clamped to the stringer joint with epoxy, milled fibers, & cabosil).
kabookey
I did not want to screw the deck into the stringers directly, so I clamped on some 1x4 planks with epoxy, fibers, & cabosil, then rounded the edges.
And then glassed over the entire stringer once again.
Status
