snowman246
- Oct 13, 2015
- 193
No Title
Last night I went to my dads shop and cut out two pieces of 3/4" exterior plywood for my transom. Once I get the two sandwiched together with resin and cloth, I will continue to glass the entire piece prior to installation. When that is complete, I will install the outdrive back on the boat and make the proper cuts for the steering arm travel.
I will prep both surfaces and install onto boat. I ordered 3 gallons of resin for the job so I will have more than enough. I will use CSM between the two surfaces for a strong and thick bond.
I plan on drilling the 6 bolt holes before I install and using 3/8" bolts, I will use the current bolt holes to help provide pressure and a permanent position during the installation...aka-I will bolt the new transom in place onto the boat. I also plan on using a couple of 2x4's on the inside of the new plywood to put even pressure across the new transom for a good solid bond of resin.
