"Now THAT'S more like it!!! Thanks for the detailed description. With the epoxy and 6.5oz cloth you now have a Tank for a transom!!!
As I said, not typical for this forum but very well done. You will be following up with an overcoating of the several layers of the 6.5 oz fabric and resin on the outside and tabbing to the hull as well or will you use a heavier fabric like a 17oz biax???"
Wood, Thank you and that is correct. Once the transom is fully cured, I will start cleaning up the surrounding areas and begin the process. First thing is the back side of the transom. Top and both sides need to tabbed in, remember the transom is wider than the hull mount surface area, I have to seal those joints together. I will have to use fully soaked pieces of CSM for the 90 degree corners. Dip the CSM into the resin and install in place. I have to use CSM because the fabric will not hold the 90 degree angle as well while the resin is curing.
Once that is complete, I will use the same 6.5 ounce fabric and place 2 layers on the engine side of the transom, making sure it lays over the top and sides to completely seal the new wood.
Finally, I will seal the entire inner area where the center hole is cut out. I plan on using one layer of cloth and resin to seal the wood.
Willy, I was kind of nervous about it as well but I have had rubber plugs leak as well. I plan on using some teflon tape on the plug each time i install. Little extra work but totally worth changing to a new plug housing that isn't 27 years old. Also, I am installing an auto bilge and a manual bilge (console switch controlled). Total of 1300 gallons per hour for that just in case moment.
