- Jul 18, 2011
- 19,149
Re: 1991 Formula 242 Stringer & Bulkhead Repairs
Nice thread, I like what you did with the drainage in the center section where the fuel tank lives. My boat does not have drainage in the center section and I was thinking of adding some . . . see pics below
It has ribs every 16" or so throughout the hull and as you can see in the photo it traps water. The drainage is from the cuddy all the way back to the bilge, bypassing the fuel tank section. When I removed the foam and fuel tank, the bottom 1/2" of foam under the tank was pretty well soaked. Any condensation that accumulates in the center section has nowhere to go. I was thinking of adding about 1" of Nida Bond right on the keel and adding drainage to the bilge, so that water would not get trapped and would have a place to go.
I am concerned about pro's & con's of adding drainage . . . is it better to have the drainage versus isolating the fuel tank section. It appears that the folks at Formula chose to isolate the tank from the engine compartment.
Thoughts ???
That looks like the way my rot started but went a bit further up the stringers to the helm... I used Nida Bond to repair my motor mount that was somewhat hollow.... Pics of everything are in my thread below![]()
Thoughts ???
