SteveinVA
- Dec 16, 2010
- 106
Re: 1994 Bayliner Rendezvouse Ressurection
Quick question? I am running into alot of dry glass under some of the plywood installed on the stern area for ladder mount, and rear tow(?) u bolts and such. Do I have to remove this stuff all the way down to the hull or can I just roll on some resin? The problem is I started to remove it and just kept digging deeper and deeper trying to get to the hull and I think I have pulled off the inner most layer of the hull(small section of woven roven). what I want to do now is just cutoff what has peeled up, spread some resin on the dry glass, and sand smooth,then add some CSM to build it back up. anyone see a problem with that? I dont know what else to do other than that. See the pic below, the whitish/yellow areas is dry csm under a layer of resin soaked cloth. It bugs me...
