HunkerDown
- Dec 12, 2004
- 2
We have twin 1995 DT75's on our 1995 Seacat SL1. Owned it for a year now and all of a sudden the port motor is giving me a warning on the monitor which is illuminating the Temp/Rev Limit light and activating the buzzer. Have checked the oil flow sensor (is clean & functioning to spec).I have not over revved or over heated the motor or run it low on oil. The warning only appears on the port motor. I swapped the temp sensors and the suspect sensor sets off the same warning on the starboard motor. I have ordered a new sensor but have a question. When the key is turned to the ON position is the warning buzzer and temp/rev limit light supposed to come on similar to OMC motors? Also tested the Cylinder head temp sensor and it was to spec. Any help would be appreciated.<br />Thanks
