1996 150 HP HeadGasket
T Smack
Do they make a headgasket for this motor? Or do you just use the rubber O ring and high temp silicone?
wilde1j
Re: 1996 150 HP HeadGasket
Look at parts list on BRP Evinrude site.
T Smack
The website show to use the o-ring but when i search on other website it show that they make headgasket for it. Don't know which is better.?
wilde1j
If you want definitive info, get an OEM shop manual. I don't know about the use of any silicone with the O rings.
This is what BRP website shows:
36 0335523 O-RING, Cylinder head. Included in Powerhead Gasket Set
There may be an adhesive used to hold the O rings in place during assembly. Again, consult the OEM shop manual. I don't think there's a conventional head gasket choice here.
T Smack
Thanks for all your help. I also notice that those little hole surrounding the piston on the block and also on the head is covered up by black silicone. Is that suppose to be like that? I thought those inlet hole are for water to go through to keep it cool?
Chris1956
My '98 Johnny 150HPV6 calls for a bead of silicone around each water port on the block, and the use of the Oring around the cylinder. I believe the oring should be dry. I recommend an OEM manual, since you still need torque sequence and values, and my manual is at home.
Dhadley
O rings only, there are no head gaskets for the 60 degree loopers. Be careful when you put the black RTV around the water passage holes. If you use too much the hole will get blocked and bad things can happen.
T Smack
Thanks and that's exactly what I wanted to know. Does it call for what type of RTV? Or what do you guy recommend?
