joewithaboat
- Jul 3, 2011
- 1,172
Re: 1996 mercruiser 5.7 with thunderbolt ignition ... Top End knock Please Help
Correct, 350 blocks are plentiful enough that most of the time it is smart to start with a fresh one as to not have to sonic check the wall thickness.
If we have a block that we have spent money on in other areas... line hone & fitted with aftermarket caps, zero decked, lifter bore mods etc. We will go to .060 after checking wall thickness. Most of the time the walls will become pitted from the sand casting before they get too thin.
Ok that makes a little more sense to me. So basically what your telling me is when I do need to have everything redone I should just buy a new long block instead of having the one I have now refreshed.
