Just returned from trip this weekend and was having problems with 9.9. Probably 2 problems. First one dealing with motor stalling after about 5 minutes. Squeezing bulb seemed to correct that problem so I'm guessing gas line leak. Problem #2 is more serious. I just changed oil before trip because it was low (first time) and had motor oil residue on lower shaft. Ran it all day Saturday, motor died. After boat was loaded I checked oil level and it only about an inch left on the dipstick! Filled it back up and ran it for a little while but decided to use big motor until I figure out where the oil is going. Trailered it back home (350 miles) and during gas stops I would check it. Lower shaft was leaking oil out of what appears to be water drain holes just above the lower gearcase Any ideas?<br /><br />John
